Hypothetically speaking, if I thught my C5 LDS was low, and I topped it up to where it should be, then discovered I had infact had it on the normal height instead of its lowest height, what would happen?
And if I kept driving around pretending it hadn't happened? Does it have an escape?
C5 Suspension fluid
mooseshaver
C5 Suspension fluid
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
mooseshaver
I don't really have anything to get it out with. Think I will just leave it.
Gone cars.
Gone cars.
- x 5583
- x 1044
mooseshaver
Not got those, but I could buy one from somewhere. Would quite like to know if it is dangerous to run it like this?
Gone cars.
Gone cars.
XantiaMan
- x 18
Use a trigger off a bottle from the kitchen, just dont let the missus catch you!
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
MikeT
- x 232
mooseshaver
Yes on the lowest setting, and no interesting glass thingy to look at, juse a cap that tells you you shouldn't remove it, and then look in the hole like you used to look at radiatorsMikeT wrote:Do you have to check the level on it's lowest setting with these C5's then?
Gone cars.
Gone cars.
Clogzz
- x 40
Can’t be dangerous, the worst that can happen is that the excess will overflow at the low setting, which is when the tank is fullest.dangerous to run it like this?
Checking the level at the low setting isn’t a bad idea, because when you nearly brim it there, the level is necessarily correct for the higher settings.
There’s no sorcery to LDS and LHM filling; the limits are lack of fluid at the high setting, and overflow at the low setting.
After syphoning the old LHM from the Xantia with a transparent plastic tube, I refill close to the brim at the low setting, and the indicator for the high setting has always fallen into place.
Picture of Xantia tank with overflow pipe on the filler cap:
2002 C5 2.0i AL4 239,000 km 76372389
mooseshaver
Thanks Clogzz, will stop worrying now
Gone cars.
Gone cars.
