C5 Suspension fluid
mooseshaver
C5 Suspension fluid
Unread post by mooseshaver »
Hypothetically speaking, if I thught my C5 LDS was low, and I topped it up to where it should be, then discovered I had infact had it on the normal height instead of its lowest height, what would happen?
And if I kept driving around pretending it hadn't happened? Does it have an escape?
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
juraj
Unread post by juraj »
can you siphon some out? ... hypothetically ...
mooseshaver
I don't really have anything to get it out with. Think I will just leave it.
Gone cars.
x 5586
Can you suck it out with a bike pump?
Turkey baster?
x 1044
Unread post by wheeler »
a syringe with a piece of washer tube attatched ?
mooseshaver
Not got those, but I could buy one from somewhere. Would quite like to know if it is dangerous to run it like this?
Gone cars.
XantiaMan
x 18
Unread post by XantiaMan »
Use a trigger off a bottle from the kitchen, just dont let the missus catch you!
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
MikeT
x 232
Unread post by MikeT »
Do you have to check the level on it's lowest setting with these C5's then? That's bound to catch a few loyal (ex-xantia) owners out and a smattering of incompetent back-alley mechanics ... oh, probably me too :lol:
mooseshaver
MikeT wrote:Do you have to check the level on it's lowest setting with these C5's then?
Yes on the lowest setting, and no interesting glass thingy to look at, juse a cap that tells you you shouldn't remove it, and then look in the hole like you used to look at radiators
Gone cars.
Clogzz
x 40
Unread post by Clogzz »
Can’t be dangerous, the worst that can happen is that the excess will overflow at the low setting, which is when the tank is fullest.
Checking the level at the low setting isn’t a bad idea, because when you nearly brim it there, the level is necessarily correct for the higher settings.
There’s no sorcery to LDS and LHM filling; the limits are lack of fluid at the high setting, and overflow at the low setting.
After syphoning the old LHM from the Xantia with a transparent plastic tube, I refill close to the brim at the low setting, and the indicator for the high setting has always fallen into place.
Picture of Xantia tank with overflow pipe on the filler cap:
2002 C5 2.0i AL4 239,000 km 76372389
mooseshaver
Thanks Clogzz, will stop worrying now
Gone cars.
