Hydraulic Pressure Regulator
reservex
Unread post by reservex »
1999 1.9td Estate Diesel
There is LHM leaking out of the rear of my pressure regulator opp end to the shere, ive not yet been able to determine if it is on the regulator or a pipe connection, is it common for a regulator to fail? Does anyone know if a recon regulator can be found if this is the problem and if so what is the procedure for changing it, or could it be a pipe seal? The suspension and brakes perform normally and there is no excessive ticking from the accumalator suggesting it is working properly Any help appreciated.
slim123
Unread post by slim123 »
Leakage from the rear of the regulator is quite a common problem, it's a sinch to change, just a case of nuts and bolts. The regulator fitted to the later cars does not use the citroen fitting and seal arrangement on the 6.35mm feed pipe, this model uses a much finer thread size so make sure that you get the correct one for the car.
It will be worth checking the main accumulator sphere as running with a flat sphere can cause the leak, certainly if the main accumulator is over 3 years old, I would be changing it at the same time as the regulator.
Pleiades do the recon units at a very reasonable price, give them a call on 01487 831239, although I think that it may be a tad late now, untill Monday, as they are not allways in at the weekends.
Regards
Slim.
reservex
Thanks Slim, will give them a call Monday
jeremy
Unread post by jeremy »
Its well worth cleaning the regulator very carefully and establishing exactly where the leak is. If its coming from somewhere other than the regulator it will still be there when you've replaced it.
Possibilities are a split in the pipework - particularly the pipe from the pump especially if its supports aren't properly attached, leaking pipe seals, and drips from elsewhere running on to and dripping from the regulator.
jeremy
bernie
Unread post by bernie »
reservex wrote:Thanks Slim, will give them a call Monday
I've got a brand new (coarse thread model) PR if your interested?
3 Fiat 124 Sport 1969x2, 1968
2 Fiat 124 Spider 1976, 1971
1 Fiat 20VT Coupe Plus
BUT maybe moving to France
reservex
Thanks for the offer will let you know if i can use it.
flygirl767
leaking regulator
Unread post by flygirl767 »
Hi - had this exact problem last year (in my Xantia 1.9TD). Being a helpless young girl - lol - I got a big specimen of the male species to look at it. It was leaking from the end (offside if sitting in car). He tried everything to fix it but to no avail. Eventually I had to bite the bullet and get a replacement from a breakers (£40). It worked perfectly. Apparently the breaker said there a quite a few pipe variations so make sure you count the number of pipes that enter it. The bolt fittings though, are the same. Quite easy to fit. Mind you, by the time you get this, you have probably fixed the problem. Best of luck. Any trouble getting a replacement - give me a message. Love, Michelle.
x 94
Unread post by citronut »
Michelle
the O/S = the drivers side if you are in or out of the car and the wright hand side when sitting in the car , the rear of the regulater is towards the N/S,
if you had something leaking at the O/S it was probably you hydaulic pump
kind regards
malcolm
flygirl767
girls and directions
Malcolm (Citronut) is right, Reservex. Just goes to prove the scientists are right about girls and directions - lol. I meant the nearside (by the pavement).
Love, Michelle
Johnno
(Donor 2022)
Unread post by Johnno »
I came across the problem of different threads when trying to fit a replacement PR to the 2.1 - I assumed it was just French perfidy. Can anyone say what year the threads were changed so that I can go looking for the right item?
John
'59 C5 2.2 173 VTX+ saloon, Jaguar 3.8 MkII 1961
RIP - '07 C5 2.2 173 VTX+ Estate
flygirl767
perfidy! What a lovely word. Just thought I'd share that with you
Johnno
(Donor 2022)
Glad to have brought a smile. Usually applied to us by our Gallic cousins as in "perfidious Albion". I guess they were familiar with British Leyland...
John
XantiaMan
x 18
Unread post by XantiaMan »
flygirl767 wrote:perfidy! What a lovely word. Just thought I'd share that with you
Yep, means to be perfect like! I find the additon of 'Idy' to the end of certain words most useful!
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
x 5634
Here is a fine example of French Perfidia
