Ok what could be causing this? I ran out of diesel this morning and now the EM light is on (after putting some in and giving all the crap a blast through). Is there anyway to read the codes without going to Citroen or having a code reader? Is the light likely to go out after a few more miles?
Ran out of diesel....now have EM light
Toby_HDi
- x 3
Toby_HDi
- x 3
Re: Ran out of diesel....now have EM light
EDIT: Duplicate post
mrbump
Toby_HDi
- x 3
Crack them until fuel comes out and then tighten them up again? Or tighten them up after battery is reconnected?mrbump wrote:Try cracking all the injector unions one by one (the 17mm nut on top of the injectors) until fuel comes out. Then disconnect the battery for 5 mins and reconnect.
Make sure you have your stereo code first though!
nick
Toby_HDi
- x 3
nick
Toby_HDi
- x 3
nick
On an HDi the pressures involved are way higher than on a traditional diesel injection system. Get part of your body in the way and it will literally cut right through the bone!
Also the official recommendation on an HDi is that if the injector unions are disconnected for any reason then the complete set of pipes from the fuel rail to injectors should be replaced with new. There is a possible risk of contaminating the fuel system too.
mrbump
steelcityuk
Toby_HDi
- x 3
paulbx
Connector pressure
If you wanted to crack the unions what should you do on a Hdi?
Wait x hours for it to de pressure or is there another way?
PaulB
PaulB
Broomie(paulB) Xantia Hdi 90 estate
steelcityuk
As post by Nick, this is the official line -
...the official recommendation on an HDi is that if the injector unions are disconnected for any reason then the complete set of pipes from the fuel rail to injectors should be replaced with new. There is a possible risk of contaminating the fuel system too.
Steve.
Steve.
not applicable
- x 1056
Re: Connector pressure
The official line is you must wait 30 seconds after the engine is switched off before starting work on the fuel system.paulbx wrote:If you wanted to crack the unions what should you do on a Hdi?
