Ran out of diesel....now have EM light
Toby_HDi
x 3
Unread post by Toby_HDi »
Ok what could be causing this? I ran out of diesel this morning and now the EM light is on (after putting some in and giving all the crap a blast through). Is there anyway to read the codes without going to Citroen or having a code reader? Is the light likely to go out after a few more miles?
Toby_HDi
x 3
Re: Ran out of diesel....now have EM light
EDIT: Duplicate post
mrbump
Unread post by mrbump »
Try cracking all the injector unions one by one (the 17mm nut on top of the injectors) until fuel comes out. Then disconnect the battery for 5 mins and reconnect.
Make sure you have your stereo code first though!
Citroen ZXTD Volcane VNTGE (Gasket Eater)
Toby_HDi
x 3
mrbump wrote:Try cracking all the injector unions one by one (the 17mm nut on top of the injectors) until fuel comes out. Then disconnect the battery for 5 mins and reconnect.
Crack them until fuel comes out and then tighten them up again? Or tighten them up after battery is reconnected?
nick
Unread post by nick »
On an HDi ?!! :shock:
Not a good idea!
Toby_HDi
x 3
Ah yer forgot to mention the engine, name gives a clue though.
2.0 HDi (110)
nick
I guess mrbump was assuming its an XUD.
You definitely don't want to crack the fuel unions on an HDi.
I think the light will go off on its own, if not it needs to be taken to someone with the appropriate computer to clear the fault codes.
Toby_HDi
x 3
nick wrote:I guess mrbump was assuming its an XUD.
Out of curiosity what would happen if I did?
nick
On an HDi the pressures involved are way higher than on a traditional diesel injection system. Get part of your body in the way and it will literally cut right through the bone!
Also the official recommendation on an HDi is that if the injector unions are disconnected for any reason then the complete set of pipes from the fuel rail to injectors should be replaced with new. There is a possible risk of contaminating the fuel system too.
mrbump
Yoeah sorry that wasnt the best advice for HDi. Some reason I thought it was 2.1.
It still is most likelt air in the lines though, or a stored code. Not sure about the functioning of the HDi ecu, but a reset may still cure it.
steelcityuk
Unread post by steelcityuk »
I'd change the fuel filter asap and check the tank pickup. If you get c**p through to the injection pump or injectors it's a really big bill.
Good luck with it though.
Steve.
not applicable
Toby_HDi
x 3
Cheers fellas. It has now gone out of its own accord. Put a bit more diesel and fuel gauge is stuck now lol. Assume its just the sender unit stuck. Hopefully will sort it next time I fill up.
paulbx
Connector pressure
Unread post by paulbx »
If you wanted to crack the unions what should you do on a Hdi?
Wait x hours for it to de pressure or is there another way?
PaulB
Broomie(paulB) Xantia Hdi 90 estate
steelcityuk
As post by Nick, this is the official line -
...the official recommendation on an HDi is that if the injector unions are disconnected for any reason then the complete set of pipes from the fuel rail to injectors should be replaced with new. There is a possible risk of contaminating the fuel system too.
Steve.
not applicable
x 1056
Re: Connector pressure
Unread post by wheeler »
paulbx wrote:If you wanted to crack the unions what should you do on a Hdi?
The official line is you must wait 30 seconds after the engine is switched off before starting work on the fuel system.
