Xantia 1.8i 1996 auto
mikep
just noticed whenever I pull away from standing at lights or from a standing start- the red emergency warning stop flickers on but disappears once I'm moving. Is there anything I can do about this please ?
mikep
Citroen Xantia auto sx 1996
Xaccers
- x 185
Check your coolant level asap.
DIY sphere tool
DIY sphere tool
AndersDK
mikep
emergency warning light
Thanks guys, a minute quantity of LMH seems to have done the trick !
mikep
Mandrake
- x 694
Re: emergency warning light
Hi Mike,mikep wrote:Thanks guys, a minute quantity of LMH seems to have done the trick !
I doubt a minute quantity is enough - the level is checked with the suspension height set to maximum - when the suspension is at normal height the level in the tank will be MUCH higher, which means if the low level light was activating at normal driving height the oil level in the tank was VERY low.
Please make sure you've checked the level at maximum suspension height, as what you describe suggests the level was about 1 litre short.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
