Xantia 1.8i 1996 auto
mikep
Unread post by mikep »
just noticed whenever I pull away from standing at lights or from a standing start- the red emergency warning stop flickers on but disappears once I'm moving. Is there anything I can do about this please ?
mikep
Citroen Xantia auto sx 1996
MikeT
x 232
Unread post by MikeT »
Check your LHM fluid level?
Xaccers
x 185
Unread post by Xaccers »
Check your coolant level asap.
DIY sphere tool
AndersDK
Unread post by AndersDK »
Check your engine oil level ASAP.
Anders (DK) - '90 BX16Image
mikep
emergency warning light
Thanks guys, a minute quantity of LMH seems to have done the trick ! :D
mikep
x 694
Re: emergency warning light
Unread post by Mandrake »
mikep wrote:Thanks guys, a minute quantity of LMH seems to have done the trick ! :D
Hi Mike,
I doubt a minute quantity is enough - the level is checked with the suspension height set to maximum - when the suspension is at normal height the level in the tank will be MUCH higher, which means if the low level light was activating at normal driving height the oil level in the tank was VERY low.
Please make sure you've checked the level at maximum suspension height, as what you describe suggests the level was about 1 litre short.
Regards,
mikep
LMH
Hi Simon, point taken, I will check again using your instructions.thanks,<<
regards Mike
mikep
