There is an excellent guide to removing and fitting them in the Handy Hinst & Tips section.
Presumably Citroen would sell them to you
Water damaged trims?
admiral51
- x 389
i assume you are after the silver bit of the trim
you can prise them out with a small flat head screwdriver start about the middle of the trim and get the driver to pop the bottom out. they are held in by 'L' shaped lugs and should slide from back to front they only go in to each end by 3/4" or so
if i remember someone said halfrauds used to sell the strip by the metre
if you want something waterproof to stick the new ones in try mastik on a roll can get it from caravan accessory places etc they also call it chewing gum it will take up the gap and sticks like ^%$£!
will try and take pic of strip i removed from scrap xantia and post tomorrow with lengths etc
colin
colin
rory_perrett
Was at the kit car show at Donnington over the weekend. Noticed Car Builder Solutions had some self adhesive chrome trim at £3 metre for 12mm wide and £4 metre for 15mm wide. Not measured the trim on my Xantia yet to see how wide it needs to be. I think both the above prices are + VAT, seems a bit steep price wise but then I haven't got a price for the real thing yet from the Citroen dealer to compare.
Rory
Rory
rory_perrett
Rory
Rory
- x 94
admiral51
- x 389
admiral51
- x 389
hi superloopy
how did it go at the mot??
good news or bad
pics added on this link of trim strip
smaller length 34" longer length 40"
other is front bumper trim showing locating lugs
http://aolpictures.aol.co.uk/galleries/xantiapics
colin
good news or bad
colin
