Water damaged trims?
MikeT
x 232
Unread post by MikeT »
There is an excellent guide to removing and fitting them in the Handy Hinst & Tips section.
Presumably Citroen would sell them to you
admiral51
x 389
Unread post by admiral51 »
i assume you are after the silver bit of the trim
you can prise them out with a small flat head screwdriver start about the middle of the trim and get the driver to pop the bottom out. they are held in by 'L' shaped lugs and should slide from back to front they only go in to each end by 3/4" or so
if i remember someone said halfrauds used to sell the strip by the metre :?
if you want something waterproof to stick the new ones in try mastik on a roll can get it from caravan accessory places etc they also call it chewing gum it will take up the gap and sticks like ^%$£!
will try and take pic of strip i removed from scrap xantia and post tomorrow with lengths etc
colin
rory_perrett
Unread post by rory_perrett »
Was at the kit car show at Donnington over the weekend. Noticed Car Builder Solutions had some self adhesive chrome trim at £3 metre for 12mm wide and £4 metre for 15mm wide. Not measured the trim on my Xantia yet to see how wide it needs to be. I think both the above prices are + VAT, seems a bit steep price wise but then I haven't got a price for the real thing yet from the Citroen dealer to compare.
Rory
rory_perrett
Rory
x 94
Unread post by citronut »
Brian Primmer in the CCC was selling kits at last years AGM in hunttingdon, i belive they were only for the 4 doors not the bummper trim, if you cant find a contact No. for him i will try and find one
regards malcolm
admiral51
x 389
just an uopdate as been replacing leakoff pipes today and not got round to taking pics
the front and rear bumper trims are held on by L shape lugs whilst the door trim is slide and push fit
my appologies for getting it wrong again :oops:
pics will follow of bumper and door trim
colin
admiral51
x 389
hi superloopy
how did it go at the mot??
good news or bad
pics added on this link of trim strip
smaller length 34" longer length 40"
other is front bumper trim showing locating lugs
http://aolpictures.aol.co.uk/galleries/xantiapics
colin
