Symptons are;
Turn key....nothing, not even a click from the solenoid, it will do this for 3-5 try,s and then start as normal.
Took it to loacal garage who said that the cleos suffer from water ingress to the ecu, and as it happens the sun roof has been leaking for a while.
The mechanic said that the sunroof fix would be about £275 as the seal was £80 and the rest labour.
So question is, does this sound right, can the seal be got from anywhere other than renault, where is the ecu, and can I seal it against water ingess untill I can afford to get the sunroof fixed.
Oh, and is the sunroof a diy job?
Thanks in advance for your speedy replies
Robert
