Pug 205 diesel intermediate pipe leak, Picture
dreyfus
Unread post by dreyfus »
Hi, would appreciate any help. I am losing coolant from a leak on the intermediate metal pipe, I think it may need a new clip,
never done this befor, does it have an O ring in it, should I use any kind of sealant, car is 1996 only done 88000mls, had it 5years
its the best guttsiest little car I've ever owned, do I drain the coolant first,any help or tips appreciated.View of pic is under drivers side wheel arch
Image[/img][/url]
philhoward
Unread post by philhoward »
The pipe is known to rot out - replacement is usually the only option. If you don't drain the coolant before you start, then it'll do it itself when you disconnect the pipe.. :wink:
dreyfus
ha ha, thanks for reply mate,so its a new pipe then, have done a search on GSF and pugspares cant find one anywhere any one know where I could get a new one and how much they are,,cheers
x 8444
Hi Dreyfus,
GSF Stock them. Part No. T17960 Water Pipe - Metal at £9.50.
dreyfus
Hi citrojim, just what I was after,many thanks mate :D
