Sunroof Stuck
Sunroof Stuck
The electric sunroof on my Xantia stuck last night.. It is the factory fitted tilt/slide version which slides into the roof. It is used regularly (both tilt and slide).
It had been working perfectly earlier yesterday. However when I shut the tilt, opened the slide slightly and then tried to shut the slide there was no response (movement or noise).
When I got home I tried the electric control several times to no effect. Assuming an electrical problem I tried the manual wind key. There is only about a quarter turn of movement on the key and NO movement at all from the sunroof. I have had no indication of any problem with the sunroof before.
Job one is to close the roof as I have managed to choose the rainy season to enjoy this fault. Job to is dagnosis and fix. Suggestions?
C5 2l 2001 130K - daily use X-country (must change job)
Xantia 1.9TD Estate VSX 1995 111k - daily use X-county
3xBX 1xGS 1x16 TS - oh that was a Renault
Thanks for this, especially the diagram! This morning I missed the button for the rear window and hit the sunroof one by mistake. Roof slid back a bit before I removed my finger. Moved forward and then stuck again. It looks as if it is at the point at which the whole thing moves up to lie flush with the roof. Closer investigation in daylight follows.
Grrr. Now it's stuck a little further open which makes it a problem parking in public with an 'ole in the roof.
I have been peering into the opening in the roof where the motor is and I can't find how the drive gets to the moving panel. Looking at the diagrams hasn't helped much. I guess I'm looking for a sheathed cable going from above the round bit where the winding handle goes but it's a bit dark in there and not a lot of room.
I'm trying to work out a way of at least getting the thing closed so the car is secure.
Not sure where you are at with this now but if you are stuck I suggest you remove the motor from inside the car, undo the retaining screws which hold the glass in place and remove that if possible. With a bit of gentle force you should be able to push the cables back and forth. Depends how bad they are stuck. If you are lucky and you should be then you can re-seat the glass in the correct place.
The bit you should be moving is part 4 in the diagram. If you you can get some oil in there then great. If you are really lucky the roof may work again. I suspect a cable is worn though.
Have you mislaid the emergency winder handle ?
Usually it will rattle around in the bottom of the glovebox. I seem to remember it has a dedicated store clip in the glovebox, exactly to avoid rattles.
As you can see on the diagram (item 2), there is a driver relay for the motor. This means that the operating switch rarely is the problem, as the contact sets only carries the small relay coil currents.
I suspect you may have a problem with corrosion in some of the connectors, or even a burnd out realy contact set. Could also be the motor thats got worn brushes.
The relay is a special double changeover relay, to make it a polarity shifter for the motor. It can easily be replaced by 2 standard switchover relays, if you are a wizzard on car electrics.
Anders (DK) - '90 BX16Image
Anders,
I have the emergency handle. Whole thing is jammed solid.
Dave 1,
Thanks for the idea. I was at that exquisite stage of being about to bang my head on the wall. I shall try your suggestion tomorrow morning.
Meanwhile I have to go out with a plank and a bin bag to hold off the (un)seasonal weather. I have plenty of time to do the job as all my regattas have been cancelled.
Dave 1,
If you try and turn it manually whilst jammed it will damage the teeth on the cog of the motor. Do as I said. You should be able to get the cables moving. May even have to place something solid on the base of part number 4 and give it a tap initally just to get it moving. Once moved you should be able to push the cable along. If you look inside the car when this is done you can see the cable moving where the motor sits and may be able to identify any damage. I do think you will need a new cable in the end though
Sunroof Stuck
This happened to mine 2 weeks ago with exactly the same symptoms whilst away from home .
Mine also was locked solid in the fully open position and the manual winder would not budge it .
To cut a very long story short , with the ignition on and the sunroof switch depressed , I tapped the sunroof motor with an adjustable spanner ( all I had at the time and it was starting to rain) very sharply .
Bingo . it's worked perfectly ever since !
An electrician friend of mine suggests that the sunroof motor is possibly of a poor quality and may get stuck
" between poles " from time to time ?
Seems feasable as all the electrical connections were perfect , nothing intermittant or loose .
Nowadays I keep it liberally oiled and greased and operate it at least once a week .
Used to have a similar problem on mine.
Temporary solution was to open the roof on tilt then give it a sharp rap on the rear edge on each side to push it forward a little. This seemed to realign things and it would then close.
Never solved the problem and have now stopped using it and disconnected the switch.
regards
John
regards
John
Weather's turning. I'm not touching it until global warming's taken effect. Knowing my luck we'll be getting hot and wet rather than hot and dry. 8)
