2.1 TD XM with ative
x 94
Unread post by citronut »
what the fault if it jumps allong even though its got movment in the front suspention, J reg with sports mode
regards malcolm
x 8281
Malcolm, when you say it jumps along, do you mean it is feeling really hard at the front?
If this is it then your front is stuck in hard mode due, most likely, to a failed diode in the electrovalve or a totally flat centre sphere.
J reg I would expect it to be the old Hydractive I. On these, if I'm thinking correctly, the "Sport" switch puts the suspension into full-time hard mode and not a lot else. It may be worth checking this switch is doing what it should.
x 94
ok thanks Jim how do i go about checking that, i have just fitted new front spheres and im fitting a centre one this afternoon, i is a bit of a dogy though, it almost looks like shes ridding to low, but as i said before there is movment in the front susp
regards malcolm
x 1240
Unread post by Peter.N. »
Change the centre sphere first, then try it again, before you do anything else.
x 94
ok thanks Peter that was then next thing planed for this afternoon, i will report my finddings this eve
regards malcolm
x 94
now i have fitted the centre sphere as well it is all well at the front, now you can feel the rear end is hard, the owner will have to put his hand back into his pocket again
regards malcolm
x 1240
Well done! Its amazing how many people neglect to change the centre spheres, when they are responsible for the soft ride! Probably ignorance of the way hydractive works, if they have been used to one of the older types.
x 94
yep thats about right for me anyhow, as this is a first for me
regards malcolm
