Xantia Brake Bleed Order?
x 8066
I'll be hydraflushing the Activa soon.
After the stuff goes in and I've done citarobics, what order should I bleed the brakes or does it not matter?
Thanks!
x 94
Unread post by citronut »
i would say it dose not make any differance
regards malcolm
x 8066
Thanks Malcolm :)
Stempy
Unread post by Stempy »
I heard that you are supposed to do the longest pipe run first and the shortest last, but that might be poop.
Lexia ponce
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
There is a specified order; N/S/F, O/S/F, N/S/R, O/S/R.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
AndersDK
Unread post by AndersDK »
Stempy wrote:I heard that you are supposed to do the longest pipe run first and the shortest last, but that might be poop.
No need to - as it still does not make any difference.
Its taken from the steel sprung cars with the foot-on-pedal brake pressure, where you have to pump considerably to move the fluid all along the longest lines.
Id say do the Citaerobics first to minimize trapped air in the rear suspension that feeds the rear brakes circuit.
Then flush the calipers well using a long fuel hose to return the fluid to the reservoir. Just need to have engine running and pedal down.
Anders (DK) - '90 BX16Image
x 94
on so called convetional brake systems you would normaly bleed from the furthest away from the master cylender first, i dont belive this is the case with hydraulic citroens
regards malcolm
