I'll be hydraflushing the Activa soon.
After the stuff goes in and I've done citarobics, what order should I bleed the brakes or does it not matter?
Thanks!
Xantia Brake Bleed Order?
- x 8075
- x 94
- x 8075
Stempy
I heard that you are supposed to do the longest pipe run first and the shortest last, but that might be poop.
Lexia ponce
Lexia ponce
DickieG
- Monaco's youngest playboy
- x 38
AndersDK
No need to - as it still does not make any difference.Stempy wrote:I heard that you are supposed to do the longest pipe run first and the shortest last, but that might be poop.
Its taken from the steel sprung cars with the foot-on-pedal brake pressure, where you have to pump considerably to move the fluid all along the longest lines.
Id say do the Citaerobics first to minimize trapped air in the rear suspension that feeds the rear brakes circuit.
Then flush the calipers well using a long fuel hose to return the fluid to the reservoir. Just need to have engine running and pedal down.
Anders (DK) - '90 BX16Image
- x 94
