I have a 1997 ZXTD and neither of the cooling fans will work.
The fans turn freely by hand. I have tested the thermo switch and have power at both pins 2 and 3. I have shorted pins 2 and 3 across to make both fans operate but they won't. I have checked the fuse in the main fuse box and those in the supplementary box. I swapped the relays around (just in case!). The wiring harness looks fine. The earth connection is clean.
I think I'm missing something obvious so suggestions gratefully received.
Stephen
ZX Cooling Fans
- x 1238
Clogzz
- x 40
Isn’t it something like shorting pin 3 to earth for the low speed, and both pins 2 & 3 to earth for the high speed ?
Here for the BX, Tom’s post:
http://www.bxclub.co.uk/forum/viewtopic.php?p=6857
2002 C5 2.0i AL4 239,000 km 76372389
chemexhants
