ZX Cooling Fans
chemexhants
ZX Cooling Fans
Unread post by chemexhants »
I have a 1997 ZXTD and neither of the cooling fans will work.
The fans turn freely by hand. I have tested the thermo switch and have power at both pins 2 and 3. I have shorted pins 2 and 3 across to make both fans operate but they won't. I have checked the fuse in the main fuse box and those in the supplementary box. I swapped the relays around (just in case!). The wiring harness looks fine. The earth connection is clean.
I think I'm missing something obvious so suggestions gratefully received.
Stephen
1997 ZX SX 1.9TD 140k miles
x 1238
Unread post by Peter.N. »
You will probably find that the sensor operates a relay and the usual problem with relays is that the connection blades become corroded. I am afraid I dont know where it is but look for any in the area and give them a good wiggle.
Clogzz
x 40
Unread post by Clogzz »
Isn’t it something like shorting pin 3 to earth for the low speed, and both pins 2 & 3 to earth for the high speed ? :?
Here for the BX, Tom’s post:
http://www.bxclub.co.uk/forum/viewtopic.php?p=6857
2002 C5 2.0i AL4 239,000 km 76372389
chemexhants
Thanks for the replies.
Found a loose power connection behind one of the relays which is now resoldered, and this has resolved the issue.
Stephen
