The electronic speedo on my Xantia is faulty and I need to replace it. Can anyone tell me how I stand for the recorded mileage when I change it for another that will obviously show a different mileage. Is there any legal notifications I need to make to the DVLA for example?
Cheers.
Simon.
Changing a Xantia speedo
SimonT
Saxo 1.5 XD 1998
(previously owned Xantia 1.9 TD sx 1995)
- x 1432
It's not illegal to change a speedo, nor in fact to change the mileage on the existing one - what is illegal is to knowingly misrepresent the mileage at time of sale. So all you need do is keep a record of the previous mileage, and the mileage on the 'new' speedo, so you can work out the real mileage if you come to sell. Or just ignore it, and put 'mileage incorrect' in the advert
- x 1238
davethewheel
SimonT
Yeah it was the speedo, it used to show 50 mph whatever speed I did (except zero lol). The sensor is fine as the mileage was going up as it should.davethewheel wrote:never heard of a speedo packing in, like peter has suggested are you sure it's not the sensor, xantia's has a electronic sensor to detect the speed and it's not uncommon for these to pack up.
Changed it today with one from the local scrap yard and it's all ok, great to see what speed you're doing, very novel from my point of view
If anyone has had the same 50mph prob, now I've removed it I can see that the needle moves very differently from the working one. If you gently blow breath on the needle it moves smoothly and returns slowly on the good one but flies back to zero with no dampening effect on the bad one, so guess it's a mechanical fault that occurs now and again.
Saxo 1.5 XD 1998
dnsey
- x 19
- x 1238
Xaccers
- x 185
Out of interest, do people use electric drills on the speedo to match the new odometer with the old one?
DIY sphere tool
DIY sphere tool
- x 1238
- x 1432
