Changing a Xantia speedo
SimonT
Unread post by SimonT »
The electronic speedo on my Xantia is faulty and I need to replace it. Can anyone tell me how I stand for the recorded mileage when I change it for another that will obviously show a different mileage. Is there any legal notifications I need to make to the DVLA for example?
Cheers.
Simon.
Saxo 1.5 XD 1998
(previously owned Xantia 1.9 TD sx 1995)
x 1432
It's not illegal to change a speedo, nor in fact to change the mileage on the existing one - what is illegal is to knowingly misrepresent the mileage at time of sale. So all you need do is keep a record of the previous mileage, and the mileage on the 'new' speedo, so you can work out the real mileage if you come to sell. Or just ignore it, and put 'mileage incorrect' in the advert :lol:
x 1238
Unread post by Peter.N. »
Are you sure it is the speedo and not the sensor?
davethewheel
Unread post by davethewheel »
never heard of a speedo packing in, like peter has suggested are you sure it's not the sensor, xantia's has a electronic sensor to detect the speed and it's not uncommon for these to pack up.
SimonT
davethewheel wrote:never heard of a speedo packing in, like peter has suggested are you sure it's not the sensor, xantia's has a electronic sensor to detect the speed and it's not uncommon for these to pack up.
Yeah it was the speedo, it used to show 50 mph whatever speed I did (except zero lol). The sensor is fine as the mileage was going up as it should.
Changed it today with one from the local scrap yard and it's all ok, great to see what speed you're doing, very novel from my point of view :D
If anyone has had the same 50mph prob, now I've removed it I can see that the needle moves very differently from the working one. If you gently blow breath on the needle it moves smoothly and returns slowly on the good one but flies back to zero with no dampening effect on the bad one, so guess it's a mechanical fault that occurs now and again.
Saxo 1.5 XD 1998
dnsey
x 19
Unread post by dnsey »
I believe that the usual (legitimate) procedure is to write the old mileage on the back of the new speedo, together with the date of replacement. If a second-hand unit is fitted, the original mileage of that will, of course, be included.
x 1238
Well, You learn something new every day! :o
Xaccers
x 185
Unread post by Xaccers »
Out of interest, do people use electric drills on the speedo to match the new odometer with the old one?
DIY sphere tool
x 1238
Doesn't work with electronic ones I'm afraid, nothing to connect the drill to!
x 1432
That's an urban myth anyway - you just click the numbers round with your thumb.... Digitial ones are even easier to change. Plug in laptop, what would you like it read 8) Although I saw an advert recently (might have been Citroen?) which claimed tamperproof digital odo.
