I have 2 long hydraulic pipes from a Xantia and would like to know what they're for before I try and flog them.
If I supply the part numbers, can someone with access to pr-net identify them for me please?
They are:96 106 389 and 96 106 390.
If anyone needs either of these pipes, pleae let me know.
Cheers,
Antony
Help from PR NET required.
Re: Help from PR NET required.
AT LEAST THEY'RE A PAIR!!
THEY'RE THE REAR BRAKE FEED PIPES FOR RIGHT HAND DRIVE WITH ABS BRAKES AND WITHOUT HYDRACTIVE SUSPENSION.
Number 7 & 8 on the following diagram:
Andrew
08 96 106 389 01 HYDRAULIC TUBE - WITH ABS BRAKES AND WITHOUT HYDRACTIVE SUSPENSION AND 5 DOOR SALOONmacaroni wrote:96 106 389
07 96 106 390 01 HYDRAULIC TUBE - WITH ABS BRAKES AND WITHOUT HYDRACTIVE SUSPENSION AND 5 DOOR SALOONmacaroni wrote:96 106 390.
Andrew
In the past on a CX or XM etc these were the curly pipes that ran across
from the subframe onto the rear arms - if that's what they look like, for
the right price I'd fancy having them spare!!
Problem is though, how would they get here in one piece as they'd need to
be in a 5" diameter poster tube of something!?
Andrew
Andrew
