Help from PR NET required.
macaroni
Unread post by macaroni »
Hi,
I have 2 long hydraulic pipes from a Xantia and would like to know what they're for before I try and flog them.
If I supply the part numbers, can someone with access to pr-net identify them for me please?
They are:96 106 389 and 96 106 390.
If anyone needs either of these pipes, pleae let me know.
Cheers,
Antony
andmcit
x 30
Re: Help from PR NET required.
Unread post by andmcit »
AT LEAST THEY'RE A PAIR!!
THEY'RE THE REAR BRAKE FEED PIPES FOR RIGHT HAND DRIVE WITH ABS BRAKES AND WITHOUT HYDRACTIVE SUSPENSION.
macaroni wrote:96 106 389
08 96 106 389 01 HYDRAULIC TUBE - WITH ABS BRAKES AND WITHOUT HYDRACTIVE SUSPENSION AND 5 DOOR SALOON
macaroni wrote:96 106 390.
07 96 106 390 01 HYDRAULIC TUBE - WITH ABS BRAKES AND WITHOUT HYDRACTIVE SUSPENSION AND 5 DOOR SALOON
Number 7 & 8 on the following diagram:
Andrew
andmcit
x 30
In the past on a CX or XM etc these were the curly pipes that ran across
from the subframe onto the rear arms - if that's what they look like, for
the right price I'd fancy having them spare!!
Problem is though, how would they get here in one piece as they'd need to
be in a 5" diameter poster tube of something!?
Andrew
macaroni
Fantastic answer, thanks very much.
I'll see if I can "acquire" a tube from work to post them. I'll come up with a price tomorrow, but feel free to make me an offer.
Cheers,
Antony
macaroni
Citroen can't locate these parts from those numbers, for some reason.
So, make me an offer!
How does £20 + postage sound?
macaroni
Hi,
does anyone know if these will fit a CX saloon without ABS?
Citroen can't locate the part numbers any more.
Any help gratefully received.
Antony
AndersDK
Unread post by AndersDK »
Nope -
CX & BX had different pipe diameters with/not ABS fitted.
Standard non-ABS pipes are 3.5mm diameter external.
ABS piping (yours) would be 4.5mm diameter ext.
Anders (DK) - '90 BX16Image
macaroni
Thanks very much.
