Heated door mirrors
toldemoldham
Heated door mirrors
On what xantia models was heated door mirrors fitted as standard? been looking for a set for my 1998 mk2 lx been to some salvage yards but non of them have the heated mirrors fitted just the standard type even a sx model i spotted had only had standard 1ns on it
. paul.
02 c5 2.0 hdi sx estate
AndersDK
- x 8110
reblack68
dan_the_v8man
toldemoldham
davek-uk
I should have jumped on this thread earlier - but now it's finished...
Both my Xantia heated rear mirrors have stopped heating! The drivers side gave up in November and the passenger side a few weeks ago. Do the heating elements burn out? Has anyone had similar problems and found a solution? To be honest, I've been rather afraid of taking the glass out - I've had remote mirrors before that have broken when the glass is removed...
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
np
When i had my Xantia 1 of the mirrors stopped heating.I got a new glass which was about £12 iirc.Fitted it & all was well.So yes,i would say that the elements do burn out.
It was easy to change the glass.I think you tilt the glass down towards the kerb,then using a thin small screwdriver,relase the securing clip behind the glass,then the wires & out comes the glass.
53`406 est SE Hdi 140,110k
f00lzz
dan_the_v8man
np
Are they electric though?Do you have the switch on the drivers door below the elec window switch(if fitted).If not,it may be like my old VSX without leather heated seats in that they use a standard wiring loom on all models wether the options are fitted or not.I had all the wiring plugs under my seats for the electric seats you see.dan_the_v8man wrote:mine has two wires going to it but appears to do nothing
My Dad had a 96 P reg TD LX a few years ago.That did`nt have elc mirrors.
Cheers,Neil
steelcityuk
I'm under the impression they only heat when the rear heated screen is activated, could that be why they don't appear to work for V8?
I've bought some 'silver' electro paint to repair some faults on my rear heated screen. I'm hoping that it'll improve the demisting which is terrible compared to my old 405 estate.
Steve.
Steve.
not applicable
dan_the_v8man
yes that sounds reasonable. theres wiring loom going into the seat but all the adjustments are manual and seats arent heated so its probly the same case on the mirrorsnp wrote:Are they electric though?Do you have the switch on the drivers door below the elec window switch(if fitted).If not,it may be like my old VSX without leather heated seats in that they use a standard wiring loom on all models wether the options are fitted or not.I had all the wiring plugs under my seats for the electric seats you see.dan_the_v8man wrote:mine has two wires going to it but appears to do nothing
Cheers,Neil
Dec 94 Xantia LX 1.9 TD 116k - My first car
davek-uk
Thanks for that Neil. I'll be brave and take the glass out and see if I can find out why they have stopped working. I assume it's an age thing with both giving up so close together; they must have done their x hundred hours! I'm damn reluctant to buy new glass when I don't have a breakage...
np
