Heated door mirrors
toldemoldham
Heated door mirrors
Unread post by toldemoldham »
On what xantia models was heated door mirrors fitted as standard? been looking for a set for my 1998 mk2 lx been to some salvage yards but non of them have the heated mirrors fitted just the standard type even a sx model i spotted had only had standard 1ns on it :shock:. paul.
02 c5 2.0 hdi sx estate
AndersDK
Unread post by AndersDK »
The difference is the mirror glass itself, which is backplated with a heater circuit, which in turn is powered by the rear screen demister circuit.
Anders (DK) - '90 BX16Image
x 8110
Early 1.9 SX TDs have them. Or at least mine has. Wonderful things.
reblack68
Unread post by reblack68 »
Both my 1997 SX and 2000 SX have them. I've always assumed that electrically adjusted mirrors are always heated but I could be wrong.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
dan_the_v8man
Unread post by dan_the_v8man »
what about the LX?
Dec 94 Xantia LX 1.9 TD 116k - My first car :D
toldemoldham
I presume they was a optianal extra on the lx as mine aint got them on,as for the sx i spotted it might have had a alternative replacement to keep cost down, thanx anyway.paul.
davek-uk
Unread post by davek-uk »
I should have jumped on this thread earlier - but now it's finished...
Both my Xantia heated rear mirrors have stopped heating! The drivers side gave up in November and the passenger side a few weeks ago. Do the heating elements burn out? Has anyone had similar problems and found a solution? To be honest, I've been rather afraid of taking the glass out - I've had remote mirrors before that have broken when the glass is removed...
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
np
Unread post by np »
When i had my Xantia 1 of the mirrors stopped heating.I got a new glass which was about £12 iirc.Fitted it & all was well.So yes,i would say that the elements do burn out.
It was easy to change the glass.I think you tilt the glass down towards the kerb,then using a thin small screwdriver,relase the securing clip behind the glass,then the wires & out comes the glass.
53`406 est SE Hdi 140,110k
f00lzz
Unread post by f00lzz »
Thought they were a standard fit on all Xants!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
dan_the_v8man
mine has two wires going to it but appears to do nothing
np
Unread post by np »
dan_the_v8man wrote:mine has two wires going to it but appears to do nothing
Are they electric though?Do you have the switch on the drivers door below the elec window switch(if fitted).If not,it may be like my old VSX without leather heated seats in that they use a standard wiring loom on all models wether the options are fitted or not.I had all the wiring plugs under my seats for the electric seats you see.
My Dad had a 96 P reg TD LX a few years ago.That did`nt have elc mirrors.
Cheers,Neil :)
steelcityuk
Unread post by steelcityuk »
I'm under the impression they only heat when the rear heated screen is activated, could that be why they don't appear to work for V8?
I've bought some 'silver' electro paint to repair some faults on my rear heated screen. I'm hoping that it'll improve the demisting which is terrible compared to my old 405 estate.
Steve.
not applicable
dan_the_v8man
Cheers,Neil :)
yes that sounds reasonable. theres wiring loom going into the seat but all the adjustments are manual and seats arent heated so its probly the same case on the mirrors
davek-uk
Thanks for that Neil. I'll be brave and take the glass out and see if I can find out why they have stopped working. I assume it's an age thing with both giving up so close together; they must have done their x hundred hours! I'm damn reluctant to buy new glass when I don't have a breakage...
np
Unread post by np »
I think theres some kind of circlip arangement holding the glass in place.Once the mirror glass is tilted down you should be able to see it. :)
