hi
i shut my car, walk away , and the locks open on their own
can anyone advise/help
Central locking problem
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
sounds like one of the actuators is sticking or a door is not closed properly, lock it and check the door buttons are all down, if one of them lags behind its likely to be the culprit.
Stewart
Stewart
- x 31
It could be anything from a sticking button to a dead actuator/broken wire. If you manually lock the proud one the rest might work
Stewart
Stewart
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Hi all
Its a relativly EASY fix but a bit fiddly!!
If all actuators are working fine then its IS the PLUG on the door lock INSIDE the door.
Remove door trim, peel back the inner coating, remove the multiplug that plugs into the lock mechanism, spray with WD 40 or equivalent, and then plug back in!! I've repaired a many Xantia with NON working locks to cure it with this remedy.. To be sure, do both front doors.. NO need to do the rears.. Luckily the Xantia doesn't seem to suffer the Broken Wires between A piller and door like its similar friend the 306!!
Good luck.. But I'd bet a pretty good pint its that causing the problems!!
Regards
citroenxm
Regards
citroenxm
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
