http://cgi.ebay.co.uk/The-Easy-Way-To-C ... 0044028980
anyone want to buy it to find out what it says?
another great e bay item
weety
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
bxbodger
So...lets have a competition as to what advice you get for 99p. Seller say 4 household tools. Assuming he doesn't count a monster chain wrench as a household item, then I reckon he'll show us.....piece of old bicycle inner tube, big jubilee clip, hammer, and some kind of drift!!
Remember....4 items only......and he's done 'much research and testing' so probably knows things we dont!
weety
maybe he has big pipes in his housebxbodger wrote:. Assuming he doesn't count a monster chain wrench as a household item,
- x 8412
reblack68
weety
cant remember without checking (and cant be bothered) but (without wishing to be to pedantic) isnt the bolt you undo to depressurize the system a different size to the high pressure feed at the back......if uou are using a strap wrench you must be using a ratchet as well and wouldnt you chock the front wheels with an old brick (does that count as a tool)
weety
i just checked he has sold two of these 'guides'....anyone want to own up?
reblack68
I stand corrected, I used a 12mm spanner too. No strap wrench though, just the pliers. They are big.weety wrote:cant remember without checking (and cant be bothered) but (without wishing to be to pedantic) isnt the bolt you undo to depressurize the system a different size to the high pressure feed at the back......if uou are using a strap wrench you must be using a ratchet as well and wouldnt you chock the front wheels with an old brick (does that count as a tool)
Richard
Care of a 1994 205 D.
weety
do you use the brick? ........and would it count a tool?reblack68 wrote:I stand corrected, I used a 12mm spanner too. No strap wrench though, just the pliers. They are big.weety wrote:cant remember without checking (and cant be bothered) but (without wishing to be to pedantic) isnt the bolt you undo to depressurize the system a different size to the high pressure feed at the back......if uou are using a strap wrench you must be using a ratchet as well and wouldnt you chock the front wheels with an old brick (does that count as a tool)
reblack68
weety
maybe we could all club together and buy it......
or better still we could write the 'how to change a heater matrix with only five tools or household items manual'..........
davek-uk
Just to be nosy I looked through his ratings. He sells a lot of info: sphere changing, plip coding, Win XP keys, beat speeding tickets(!). All of this is, no doubt, collected from the Internet (for FREE) in one form or another. As he has 1681 feedbacks (in this guise), it means he has made in the order of £1664.19 - less a few refunds if he's a really good bloke!
A bit of a con maybe, but (as has already been said) 99p is cheap for good info and it saves you searching for it yourself. What a good idea!
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
