another great e bay item
weety
Unread post by weety »
http://cgi.ebay.co.uk/The-Easy-Way-To-C ... 0044028980
anyone want to buy it to find out what it says?
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
bxbodger
Unread post by bxbodger »
So...lets have a competition as to what advice you get for 99p. Seller say 4 household tools. Assuming he doesn't count a monster chain wrench as a household item, then I reckon he'll show us.....piece of old bicycle inner tube, big jubilee clip, hammer, and some kind of drift!!
Remember....4 items only......and he's done 'much research and testing' so probably knows things we dont!
weety
bxbodger wrote:. Assuming he doesn't count a monster chain wrench as a household item,
maybe he has big pipes in his house :D
x 8093
Maybe he is selling a link to this very forum for 99p :wink:
4 tools. Yes, that'll be right enough. 12mm spanner, strap wrench, axle stands and a mobile phone.
The mobile phone is needed to either call your local Citroen specialist or 999 when it all goes horribly wrong :roll:
reblack68
Unread post by reblack68 »
Other than a pair of ramps I only remember using two tools for mine- a comedy sized set of water pump pliers and a 9mm spanner. I suppose a pair of ramps makes it four.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
weety
cant remember without checking (and cant be bothered) but (without wishing to be to pedantic) isnt the bolt you undo to depressurize the system a different size to the high pressure feed at the back......if uou are using a strap wrench you must be using a ratchet as well and wouldnt you chock the front wheels with an old brick (does that count as a tool) :lol:
weety
i just checked he has sold two of these 'guides'....anyone want to own up?
reblack68
weety wrote:cant remember without checking (and cant be bothered) but (without wishing to be to pedantic) isnt the bolt you undo to depressurize the system a different size to the high pressure feed at the back......if uou are using a strap wrench you must be using a ratchet as well and wouldnt you chock the front wheels with an old brick (does that count as a tool) :lol:
I stand corrected, I used a 12mm spanner too. No strap wrench though, just the pliers. They are big.
Richard
weety
do you use the brick? ........and would it count a tool?
reblack68
I can't remember now. :)
I'm going to have to pay 99p to find out what he says.
Richard
weety
maybe we could all club together and buy it......
or better still we could write the 'how to change a heater matrix with only five tools or household items manual'..........
davek-uk
Unread post by davek-uk »
Just to be nosy I looked through his ratings. He sells a lot of info: sphere changing, plip coding, Win XP keys, beat speeding tickets(!). All of this is, no doubt, collected from the Internet (for FREE) in one form or another. As he has 1681 feedbacks (in this guise), it means he has made in the order of £1664.19 - less a few refunds if he's a really good bloke!
A bit of a con maybe, but (as has already been said) 99p is cheap for good info and it saves you searching for it yourself. What a good idea!
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
