door pins
davethewheel
door pins
Unread post by davethewheel »
my m.o.t on my xantia is now due and one of the problems apart from a faulty abs sensor is the drivers door, the hinge has come away at the weld on the door and also the door handle is bust so i've got a Replacement door, i've tried to remove the door pins but they seem very tight i was wondering if anyone has any tips for removing them :)
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Hi Dave, they unscrew, normal threads..
They can be really tight, and will break light duty Torx bits. Soak then for a while, hit them, use heat, and hopefully you will undo them. But rest assured, you need a decent set of bits..
good luck
John
BrianM
Unread post by BrianM »
You might need to go at them with a small set of vise grips to get them started off. Replacement pins are relatively cheap in the main dealers.
Brian
x 1043
Unread post by wheeler »
jgra1 wrote:Hi Dave, they unscrew, normal threads..
no they dont,the pins on a xantia are square & sit in a square rececss.you put it in the unlocked position & if you look at the base of the pin there is a small slot.use a small electrical screwdriver in the slot & push the small tab in there downwards,the pin will then lift off.
jgra1
(Donor 2021)
x 36
no they are not ;)
the door pins are long torx headed bolts!
your talking about the lock lifters on the inside of the car?
davethewheel
jgra1 is correct the door pins are threaded torx head bolts, i think i'll try some heat on them first just in case i end up turning the head off them, one thing i forgot to ask is my car is a mk1 xantia but the door came off a mark 2 are they the same? :D
AndersDK
Unread post by AndersDK »
Doors are the same for Mk1 & 2.
Anders (DK) - '90 BX16Image
davethewheel
AndersDK wrote:Doors are the same for Mk1 & 2.
thanks :D
x 1043
jgra1 wrote:no they are not ;)
Whoops,sorry didnt notice you were talking about the hinge pins.i was meaning the lock pins :oops:
jgra1
(Donor 2021)
x 36
no worried Wheeler.. the amount of times I misread things is amazing, especially Women :) :twisted:
