Hi All,
I noticed last Friday that my Speedo wasn't working. So I assumed the cable had snapped.
Took the car to peugeot today to get the cable changed and they found that the cable was still intact, and that the worm drive in the gearbox had gone. To repair this they have quoted me about £240 cause they need to drop the gearbox out to do it.
Does this sound right? Is there any way it could be done cheaper as money is very tight at the moment. Cheers.
Dead Speedo
PowerLee
OwenP
Oops being a bit dense.
Its a 405 (1.9td estate), It looks from the quote that the main bit is only £2.64 it the driveshaft removal and refitting is the expensive bit at £99.75 plus another 60 odd for the rest of the labour.
The parts only come to about £40. Its all the labour that gonna eat the money.
PowerLee
ACTIVE8
- x 6
As it's the labour that is the expensive part of this repair, then it would save a lot of money to take it to an independent specialist, where the labour rate will be cheaper than a main dealer.OwenP wrote:Oops being a bit dense.
