Dead Speedo
Post Reply
OwenP
My Cars:
Dead Speedo
Post by OwenP »
Hi All,
I noticed last Friday that my Speedo wasn't working. So I assumed the cable had snapped.
Took the car to peugeot today to get the cable changed and they found that the cable was still intact, and that the worm drive in the gearbox had gone. To repair this they have quoted me about £240 cause they need to drop the gearbox out to do it.
Does this sound right? Is there any way it could be done cheaper as money is very tight at the moment. Cheers.
PowerLee
My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2
Post by PowerLee »
Hi
What car is it?
I had the speedo drive cog replaced on a 405 years ago, Part was £3 but driveshaft had to come out to fit it.
Cant remember total cost im afraid :(
OwenP
My Cars:
Post by OwenP »
Oops being a bit dense.
Its a 405 (1.9td estate), It looks from the quote that the main bit is only £2.64 it the driveshaft removal and refitting is the expensive bit at £99.75 plus another 60 odd for the rest of the labour.
The parts only come to about £40. Its all the labour that gonna eat the money.
PowerLee
Past:
Post by PowerLee »
Hi
Its the little brown plastic cog on the end of the drive shaft then.
Cheap part but its the fitting it that eats your money.
The one I had replaced had split in 2, Once the driveshaft was out the plastic cog just fell apart in to two parts in the mechanics hand.
ACTIVE8
My Cars:
x 6
Post by ACTIVE8 »
OwenP wrote:Oops being a bit dense.
As it's the labour that is the expensive part of this repair, then it would save a lot of money to take it to an independent specialist, where the labour rate will be cheaper than a main dealer.
Post Reply
