Peugeot 406 Stop Solenoid
goffers
Unread post by goffers »
My 1996 Peugeot 406 LX TD won't start, there's no fuel flow to the diesel injectors. I suspect the fuel stop solenoid is sticky/failed. There's a black square box on the nearside end of the injector pump marked "Bosch", I believe that's the solenoid, but can't see how to get it off to replace it - any help greatfully received
pugxpert
Unread post by pugxpert »
has a metal cover over it or held with tamper proof screws,need to remove fuel pump me thinks to get it off,is the keypad going to green or red and green on at the same time?
EP6T petrol turbo nice engine in the 207 GT and the new mini....
goffers
Thanks for the response - the keypad is behaving absolutely normally, starts red, key in code and goes to green, engine cranks but doesn't start.
pugxpert
sounds like the stop solenoid then,you tried giving it a (-expletive removed-) with a hammer?sometimes can shock solenoid if stuck :idea:
