my 94 xantia 1.9d has developed a leak
it is coming from the top of the spindle on the pump
i have removed the arm ,spring,cable and cleaned it up and reassembled it this appears to have stopped the leak,
but if it comes back short of taking the injector pump apart i cannot see anyway of fixing it ,any suggestions and is this a common problem
diesel leak
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
I have never seen a non turbo Xantia! It sounds as though you have the simplest pump, so if it looks as though you can remove the top to get at the shaft, you probably can. I have never personaly, had one of these pumps apart, although I have worked on the DPA pump, a much earlier version, but it looks from the diagram that the top is secured by four allen screws and it seems as though the operating shafts come off with the cover. If you are taking it apart, make sure thet the top and surrounding area a scrupulously clean, you cant afford to get any dirt in it. However, before you try all that, just take the levers off the shaft and see if the 'O' ring is at the top where you can get at it.
