Citroen TV programme tonight 31/01
there is a program called citroen: the french connection, on men and motors tonight at 7pm on ntl (channel 404), maybe on telewaet and sky too.
looks good
looks good
currently no citroens
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
My reception is a bit marginal, I've got a rather large aerial and a 26db masthead amplifier fitted and if the weather isn't right I lose some channels but generally not all.Stewart(oily) wrote:On the subject of freevier TV is anyone else experiencing picture breakup during the current high pressure weather?
Stewart
If you've got the big aerial pointed in the right direction and you have an amplifier (masthead high gain) there isn't a whole lot else you can do. Make sure that the downlead (and any connections) from aerial to digibox is good and that there isn't anything else connected to the aerial that doesn't need to be. Video recorder passthroughs EAT signal, anything that splits the signal will eat half of it too.
- x 31
Thanks Kowalski, I have an approved aerial for freeview, good co-axial and a booster down at ground level which then splits to my TV and PVR as your experience some channels seem unaffected while others are not, It will not be totally satisfactory when the terrestrial signal goes off though, mind you we are now used to the super picture quality when it is working properly.
Stewart
Stewart
Eliminate all connectors in the downlead if possible (use a continuous length of high quality coax cable from aerial to box), and put the splitter (if you need it) after the Freeview box. Even minor phase disturbances can play havoc with the digital signal, so it's best to do all you can to preserve phase integrity as well as signal strength.
It was OK. Any programme on the gogglebox that even mentions the 'C' word has got to be good.
So you know now what you're going to do now then....?
http://tinyurl.com/9ttk4
or more realistically...
http://tinyurl.com/8ldhx
Andrew
Andrew
Hmm,andmcit wrote:It was OK. Any programme on the gogglebox that even mentions the 'C' word has got to be good.
Andrew
An Activa which is not red. Heresay! 8)
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Yes the activa is in the program........................for 5 seconds (no joke).Quackers wrote:I'm gonna stay up now and watch it at 3AM (and record) anybody who watched it can they tell me if the Activa is in the program? I cannot wait!
I thought the program was for Citroen enthusiasts for the days where the company were different and technologically advanced, i found it a tad boring as im far to young to have been driving DS and the like. unsurprisingly the xantia, xsara, c2,c5 etc did not feature much.
Stewart
He he he, and I get it on a coathanger...
