Driving off the car park the other day, went over one of then speed bumps, quite slowly as normal. As soon as I got over it, dash went bing-bong, and got a warning on the display "1 tyre pressure sensor missing".
I've always wondered how these work, and where they are situated. Does anyone have any info on them, to save me the trouble and expense of taking it to Citroen to sort?
And by the way, a Merry Christmas to everyone, and Happy New Year.
C5 tyre pressure sensors
pie eater
C5 2.2HDI Exclusive
Xantia 2.0HDI SX
Eunos Roadster (I'm sure theres enough room under the bonnet for that HDI)
Xantia 2.0HDI SX
JohnD
- x 72
Take a look here.
http://www.sensorland.com/HowPage040.html
Not specifically C5 - but probably similar. I have them on mine and wonder what will arise when it's time for tyre changes. Will the fitter bugger them up? Will it increase costs?
pie eater
Thanks for that, John. That leaves me with the problem of which one is faulty. I wonder if they are coded, and plugging the car into Citroens money pit will tell me which one is faulty. In the manual it doesn't seem that the in car display will tell you which one is faulty. I don't fancy driving round with that thing bonging everytime I start the car.
WHOAH hold on a minute. Bought the car from Citroen main dealer, with Citroen approved used car warranty, which says it is as good as the warranty on a new car. Watch this space, I'll let you know just how good the warranty is in due course.
C5 2.2HDI Exclusive
Xantia 2.0HDI SX
Xantia 2.0HDI SX
406 V6
JohnD
- x 72
pie eater
Mine just displays "1 tyre pressure sensor missing". Havent played with the control stalk to see if it tells you which one - manual doesnt seem to indicate that it will confirm which one. Will have a play tomorrow.
C5 2.2HDI Exclusive
Xantia 2.0HDI SX
Xantia 2.0HDI SX
- x 1044
only the mk2 C5 can tell you which tyre is low as the sensors are programed to a specific position,on the mk1 the car doesent know where each sensor is.JohnD wrote:I understood the display on the centre dashboard told you which one down.
the sensor is incorporated into the valve in the tyre & they are notouriously bad for failing.also sometimes the metal valve caps sieze onto the valve & the only way to get it of is to destroy the valve,best thing to do is to change them for plastic caps.
the recever is inside the indicator/wiper switch assembly.sometimes after a change of tyres the valves need to be re-programed.
obviously as said before check the tyre pressures 1st.
JohnD
- x 72
406 V6
- x 1044
Only the valve core should be replaced when changing the tyre,unless you really want the complete assembly replaced but they cost over £50 & need to be programed by Citroen.JohnD wrote:So what happens when the tyre fitter rips out the old valve? Will he have similar to replace it with?wheeler wrote:
pie eater
Checked tyre pressures this morning, rear offside was a little low at 28psi. Topped up and hey presto - no more message. I thought the display would tell you that pressure(s) were low, or a tyre punctured, not that a sensor was missing.
Anyway, a lesson there - Thanks Horse. Check tyre pressures before assuming that a sensor is down. Must have been just coincidence that the message flashed up as I went over a speedbump, I thought summat had fallen off!
Happy New Year to all.
C5 2.2HDI Exclusive
Xantia 2.0HDI SX
Xantia 2.0HDI SX
Mandrake
- x 694
Perhaps the pressure was almost exactly on the threshold between ok and not ok, and when you hit the bump it would cause a momentary pressure increase followed by a drop and the sensor decided enough was enough and reported a low pressure conditionpie eater wrote:Checked tyre pressures this morning, rear offside was a little low at 28psi. Topped up and hey presto - no more message. I thought the display would tell you that pressure(s) were low, or a tyre punctured, not that a sensor was missing.
The message could have been worded a bit better though...
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
