Xantia HDi cutting out
Bobby0026
Unread post by Bobby0026 »
Seasonal Greatings to you all!
I have a Citroen Xantia HDi 110 SX 2001 model, I have had a few problems with my car and maybe they are linked.
Almost always, after driving the car a few miles in the morning, the engine justs cuts off with no warnings at all. It requires me of off the ignition and restart, sometimes takes several atempts to start again. It will then drive for a few yards and stop again... this will happen a few times, then after this, the car is fine, I can drive it for hundreds of miiles without this problem, stopping and starting the car all day.
I have also noticed that the car also cuts out if I drive it a bit rough...
Another point about the above problem is that the engine seems to cut off more often when the car is low on fuel, although it still does it on a full tank too...
I was told by several people that the fault could be the low pressure fuel pump in the fuel tank, so I spend nearly £200 changing the fuel pump which made NO difference at all! :( (So I might be selling my spare original fuel pump soon)
I have also noticed that my car only does about 33MPG in town and maximum of about 53MPG on the motorwar at a steady 70MPH, this figures seem a bit low to me, could all this be linked??
Has anyone else had a similar problem and solved it?
Best Regards,
Bobby
Previous Cars:87 BX-17 RD,91 BX-17TZD
Currently Own: 95 Xantia TD SX and 2001 Xantia HDi SX (110BHp)
Clogzz
x 40
Unread post by Clogzz »
2002 C5 2.0i AL4 239,000 km 76372389
pikecrazy
Unread post by pikecrazy »
Have you checked the fuel filter ?
I hope its not the high pressure pump :shock:
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
Bobby0026
Hi Guys,
Thank you for your replies, I got the car a few months ago and I have changed the Fuel Filter, Air Filter and Oil/Oil Filter.
I too hope its not the high pressure pump...
It starts in the mornings without any problems, the problems begin after driving for a while.
Any Ideas?
I don't think it has anything to do with the glow plugs.
Thanks,
Bobby
Clogzz
x 40
Wont be the glowplugs, they're only used at start-up, and do nothing afterwards.
Looks like you've got fuel flow problems.
The second link above has 2 pages.
Look at all the posts from our experts on the second page.
Bobby0026
Thank you Clogzz and everyone else who has read my post,
I did notice one other thing, when the car does cut out, on turning the ignition key half way, i do hear a click click noise as apposed to a slight hmmmmm from the fuel pump which lead me to changing it in the first place (same problem with new one)..
I will try to trace the fuel line to look for anything abnormal.. are there any other suggestions?
Bobby
Clogzz
x 40
Bobby0026
Could a blown exhaust be causing my problem?
zxTd
Unread post by zxTd »
high fuel consumption = fuel pump"fuse"/injectors/fuel pressure loss heated 02 sensor
zxTd
also check for bad vacuum pipes on the egr system
Bobby0026
Hi Dave,
Where is the 02 sensor?
Thanks,
Happy New Year to all!
Bobby
zxTd
o2 sensor is on the manifold or the exhaust down pipe its a long thing sticking out with a cable coming from it
http://images.google.co.uk/images?q=o2+sensor&hl=en
x 1044
Unread post by wheeler »
HDi's dont have O2 sensors
zxTd
great stuff m8 just had a look, so I recon it could be down to the EGR solenoid or MAP sensor "check for failed vacuum pipe
MAP sensor is near the air filter box and EGR solenoid is near the fuel cut off switch
