C5 headlamp removal
Sir Clive
C5 headlamp removal
Unread post by Sir Clive »
I'd like to remove the headlamps from my C5. It's OK though chaps, I do promise to put them back in again :lol:
Is it a fairly easy job, or are we talking about dismembering the entire front of the car to do it?
x 1044
Unread post by wheeler »
You need to partially remove the front bumper to get at the two lower headlamp bolts.remove the 4 T-30 screws fom the landing panel,remove the 3 twist screws at the bottom of the bumper,remove the T-30 screw at the bottom corner of the bumper,then remove the screw at the edge of the bumper that goes into the wing,then you need to give the bumper a good pull to remove it.
Sir Clive
Thanks Wheeler, useful information as always :)
