Is it a fairly easy job, or are we talking about dismembering the entire front of the car to do it?
C5 headlamp removal
Sir Clive
C5 headlamp removal
I'd like to remove the headlamps from my C5. It's OK though chaps, I do promise to put them back in again
- x 1044
You need to partially remove the front bumper to get at the two lower headlamp bolts.remove the 4 T-30 screws fom the landing panel,remove the 3 twist screws at the bottom of the bumper,remove the T-30 screw at the bottom corner of the bumper,then remove the screw at the edge of the bumper that goes into the wing,then you need to give the bumper a good pull to remove it.
