Spoiler
JBUK
Its held on to the hatch by a self tapping screw and a 10mm nut on a stud set in the spoiler on each side. The screw is fairly long (around 5-6 cm)so make sure you use exactly the right length.
To fit just drill 4 holes in the correct position in the hatch using the spoiler as a template and tighten it up. No sealant/adhesive is used.
- x 94
dillosk8ter
wilkobob
