Xantia Exclusive Cruise
rossnunn
Unread post by rossnunn »
Mothers doesn't work.
I've checked the fuses & renew them to be sure but still no joy. I've been told there is a pipe that can pop off somewhere under the battery? Anyone got anymore info on this before I start pulling things apart?? She's going away Saturday & have been told, she'd like to try it out (i.e fix it or else!)
Cheers [:o)]
x 1044
Unread post by wheeler »
the brake light switch inside the pedal is probably the most common cause of CC failure on the xantia even if the brake lights are working ok.i believe there are 2 sets of contacts.
zzf00l
Unread post by zzf00l »
I may be wrong but I was told by a stealer that it required a new brake pedal!!!
DoubleChevron
Unread post by DoubleChevron »
Mine started that recently. I'm sure it's the pedal switch as I managed to get it working (just once) by lifting the pedal with my foot.
It's a "oneday" fix when I get time
seeya,
Shane L.
rossnunn
cheers all, ok is there a easy way of testing these switches? I'll be looking out for them while im at the breakers tomorrow
x 1044
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zzf00l</i>
well kind of,the switch is under the rubber grip of the pedal.
rossnunn
anyone got a exploded diagram?
x 1044
the switch (no2) comes complete with pedal base & rubber part.
rossnunn
fanks
rossnunn
i assum the swich is item 2?
x 1044
yeah its number 2
xantiav6
x 3
Unread post by xantiav6 »
I fixed the brake pedal switch on mine by taking it apart and cleaning the contacts. It has been fine now for 6 months.
The other common problem is the vacuum hose to the control valve. It splits just where it is pushed onto the valve. To inspect this, you need to remove the front bumper.
FrenchLeave
Unread post by FrenchLeave »
Is item 3 the dreaded spring I've been hearing so much about?
Mandrake
x 694
Unread post by Mandrake »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by FrenchLeave</i>
Yes it is [:D]
sdabel
Unread post by sdabel »
Is the switch the same for cruise and brake lights?
