Electro guru needed
bernie
Electro guru needed
How would you test a diode that is connected in parrallel to a relay coil?
nb. the diode cannot be disconnected.
ActivaV6uk
Kowalski
Ideally you'd use a component tester, a place I used to work at had one. Basically, it had a CRT and a couple of probes and it applied an voltage to the component and drew on the screen a sort of graph.
In abscence of a proper tester, have you tried checking the resistance in one direction then swapping the terminals over and seeing what the resistance is like in the other? With the diode in parallel to the coil, one direction should give the coil resistance (i.e. the diode doesn't conduct) and the other would give the coil / diode parallel resistance (i.e. the diode does conduct) which should be pretty low. An infinite resitance in one direction and no resistance in the other would indicate that the coil is shot, the same resistance in both directions would indicate that the diode is dead, you're looking for a coil resitance in one direction and a low (diode forward bias) resistance in the other.
bernie
Kowalski
dnsey
- x 19
bxbodger
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Kowalski was in Vanishing Point.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
And Voyage to the bottom of the sea! He was the stroppy sidekick if I remember rightly, the Captain always shouting "get the lead out, Kowalski...."
Kowalski
tomsheppard
Richard Green
Stempy
Kowalski
Richard Green
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stempy</i>
Diodes go short when too much current is passed through them and open when too much voltage is applied across them.
thats why diodes/capasitors are fitted to equal the flow of voltage.
Stempy
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Richard Green</i>
Just to be a pedant, voltage never flowed anywhere, current flows, voltage is potential difference[8D]
