2002 belingo 2.0 hdi
Post Reply
tonespeed1999
My Cars:
Post by tonespeed1999 »
2002 belingo 2.0 hdi,wont start!.no problems to date.just got in it this morning and wont start.
have noticed that the glow plug light doesnt come on.
i have tested the glow plug relay and the double relay next to the battery as per auto data and they aye ok,done a diagnostic check and it shows a code of P1352, this isnt listed on auto data!
has any one got any ideas? i think that the ECU has a fault?
tonespeed1999
My Cars:
forgot to mention,doesnt look like fuel pump is operating or fuel injectors working either?
Dave Bamber
My Cars:
Post by Dave Bamber »
Check the fuel pump in the tank is still alive.
My Cars:
x 732
Post by wheeler »
are you sure its definitely P1352 as this is Ignition Coil A Primary Circuit Malfunction ? this would be a bit strange on a diesel unless it is refering to the injector charge capacitors inside the ECU.
Is this the Bosch or Siemens system ? i think it is unlikely to be the ECU at fault.has any work been done to it recently ?
My Cars:
x 732
Post by wheeler »
yeah if its a bosch system check the low pressure pump in the tank,if its a Siemens injection system then it doesent have a lift pump in the tank so dont think that it is not operating if you have this system.
tonespeed1999
My Cars:
it says seimens on the fuel rail.the code is P1352 according to a SNAPON SCANNER.can i access the fuel tank through the rear floor? if so im stuffed!!.the van has been kitted out as a fish van!!
Jon
Post by Jon »
So, if it is the Siemens system, as Wheeler points out, they do without the in-tank lift pump, so you don't need to go there.
Wouldn't bother about the glow plug light, I've never seem mine come on ever (2004 Blingo Hdi with Siemens system). Got to be a sensor or ECU fault surely.
My Cars:
x 732
Post by wheeler »
im assuming that the engine is turning over on the starter fast enough ? does it even try to start ? have you tried priming the hand primer pump for the fuel ? all injectors/sensors/connectors plugged in ok ? could possibly be a faulty injector.
tonespeed1999
My Cars:
turns over ok,but no feed to glow plugs or light on dash,no feed at injectors,all multi plugs ok.tried spare key as well.
jeremy
My Cars:
Post by jeremy »
daft but does it have fuses?
Jeremy
tonespeed1999
My Cars:
all fuses are ok.
Post Reply
