2002 belingo 2.0 hdi,wont start!.no problems to date.just got in it this morning and wont start.
have noticed that the glow plug light doesnt come on.
i have tested the glow plug relay and the double relay next to the battery as per auto data and they aye ok,done a diagnostic check and it shows a code of P1352, this isnt listed on auto data!
has any one got any ideas? i think that the ECU has a fault?
tonespeed1999
Dave Bamber
- x 1044
are you sure its definitely P1352 as this is Ignition Coil A Primary Circuit Malfunction ? this would be a bit strange on a diesel unless it is refering to the injector charge capacitors inside the ECU.
Is this the Bosch or Siemens system ? i think it is unlikely to be the ECU at fault.has any work been done to it recently ?
- x 1044
tonespeed1999
Jon
- x 1044
tonespeed1999
