Body Kits for Xantia Needed
narnie
Does any body know of any where i can get a good body kit for my xantia iv tried every where, i want something agressive and bit rounder plzzzz help i want to be different and the xantia has every thing i require i.e hydrolics, ppl pay upto 3k to get these babies so i am very gratefull
Kowalski
A few companies do Xantia body kits but they're pretty rare, the Xantia doesn't have a big following in the modding community.
The pipework on Xantia hydraulics is all low bore and the pump has a minutely small output so its not really suitable for making the car jump etc. which I assume is what you want it to do.
narnie
bxbodger
Presumeably this is the sort of thing you are after-http://www.citroenet.org.uk/html/b/bodykits3.html
I don't know where these people are but a web search should turn them up- I have seen the Cituning name a lot in conection with BX twin headlight kits, etc.
ACTIVE8
- x 6
VLL
zorgman
zorgman
weety
try here mate
http://lefrancaisconnection.com/cituning/Default.aspx
Stempy
weety
ACTIVE8
- x 6
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by weety</i>
or what happens when the system depressurises itself,where do you get your jack underneath?
Though i liked the estate back bumper kit with four exhausts....,might cut up some hoover tube later and go and mod mine
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stempy</i>
So what happens when you fit a body kit and then need to depressurise the system??
Stempy & weety have "raised" [:D] important issues in these two posts, which anyone contemplating to stick a body kit on should bear in mind, otherwise it could cause many problems by "Chaving" an Xantia.
bxbodger
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">So what happens when you fit a body kit and then need to depressurise the system??<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Quite simple- put the axle stands under first!!!
If it depressurises itself, you just use an old scissor jack, one should go under as they are only about 2" high when flat.
davek-uk
