alpine and speed pulse wire
im bidding on an alpinr navi headunit on ebay and it says it rqures a speed pulse connection and wanted to know where it was aon a phase 1 DTurbo, and also if it was needed?
http://www.andyspares.com/discussionfor ... C_ID=12037
as long as its not a cable driven speedo,the same wire can be found at the back of the instrument panel but you would need a wiring diagram to find out the exact pin number.
Oops didn't see the "navi" in the original mail.
If your pug has a digital dash, you should be able to get the signal from the rear of the instrument panel. Haynes schematic may help. The older 306 models have analogue speedos (like my '93 XTDT model), driven by cable, however the tacho is electrical.
