National tyre have got a buy one get one free offer on tyres at the min , it says "wheels may require valves and balancing, a charge will be made for this service" or something like that, does anyone know how much they charge per tyre? I dont want them to try and pull my pants down for an extra 20 quid or something!
Cheers
paul
national tyre offer
Dave Bamber
arry_b
Why not call them and find out. Most independents charge about a fiver for a valve and balance near me.
Then ask them to price match on the balance and valve (see their web site), AND - book your fitting through their web site for an extra 10 percent discount.
Don't worry about using their offers against them, they would indeed stiff you on the cost of the balance otherwise.
drpau
The tyres are only cheapy Barum's, £40 for two. Ive got Michelin Energy on the front at the minute but they are close to the tread indicator now and $ is tight at the moment [:(]. Has anyone had Barum tyres before? I'd like to save a bit of money but not if it means Im gonna be driving through walls through no fault of my own[B)] .
If it was on the rear I wouldnt bother with the balancing Dave but they will be on the front, why would you want new valves? Just if youve got a leak.
Cheers for the tip of the web discount arry, Ill have a look at that.
Oops, just realised that I shouldnt really have put this in the Cit' section[:o)]
davethewheel
drpau
Forth
dan.2cv
Since when was Yokohama a budget brand? I had a set of A509s on my old car which were the best tyre I have ever driven on in the dry. I say in the dry because I don't think I ever drove on a worse set in the wet......They did however wear out very quickly.
I have budget tyres on my Xantia front. They were £35 each and no complaints with performance -'adequate' would sum them up, it just depends what you want from your tyres, you get what you pay for.
modi
kid
better still buy the avon zv3, only £84 for two fitted, valve balance etc.
these rrp is £75 ish each any worth every penny.
for those that have read my thread 'terrible xantia handling on motorway' will know my 11 month problem has now been solved simply by putting these on the front. these offer incrediblke grip, very quiet, fantastic handling and braking int the wet, trust me ive just been on the m42 at 70 in the wet and it felt fantastic, quiet and smooth. also no understter on these, which blighted my previous set of tyres.
i very much agree you get what you pay for in tyres, and these are a bargain.
is it worth saving £25-30 per side for these extra safety, handling and comfort features, plus over the life cycle of the tyre the extra cost is nothing.
ive found th efollowing website useful too
http://www.tyretest.com/
ItDontGo
kid
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ItDontGo</i>
Cheap tyres are OK. They usually just wear quite quickly and even if they have a little less grip then its not that bad. If you 'end up in a wall' as you put it then it will be your fault not the tyres.
you must be brave, with budgets on the front of my xantia, it felt unsafe over 60mph, and pulled on hard braking, needless to say the've been scrapped. if you feel safe in them then good for you, me never, in a xantia anyway. in a 600kg corsa (for eg) the difference is probably minimal
yangreen
I had some awful Goodyears on my Pug 306 Dturbo when I got it. Wheelspin in 2nd was not uncommon when it was wet and they locked up a treat too. Fitted Avon's which were wonderful until they wore a little - then iffy in the wet too.
Currently have Firestones which are rubbish on the 2cv but seem pretty good on the Pug.
When I had a BX TGD, I fitted remoulds (I was very skint in those days) and had no problems at all. No turbo probably helped though!
PowerLee
Im sticking to the Michelin Pilots.
I wont put any kind of Ditchfinder tyre on my car.
Ive tried Goodyears, Pirellis, Continentals, Dunlops, Bridgestones, Firestones & they dont grip or last half as well as the Michelins do.
I know Michelins cost a fortune but its a price worth paying at the end of the day.
