flat f**king battery
meexi
my Xantia had a flat battery that seems to be intermitant the only common denominator is that the alarm goes off and quickly flattens the battery. Has any one else had this problem?
ActivaV6uk
Robin
Try isolating the interior sensors by holding the switch in until the alarm indicator light comes on steady and then locking up as normal. If it cures the alarm triggering then it's the interior sensors that need changing.
A triggered alarm shouldn't flatten a good battery so check the negative lead back to where it connects with the engine. This is often just a crimped connection and causes quite a heavy voltage drop both when charging and especially when starting. Gives every symptom of a flat battery and reduces the charge voltage by as much as 1.5 volts. Robin
druist
