xantia caliper
xantia caliper
i've just put a new caliper and pads on the o/s front of a xantia.i started to bleed the brakes with the engine off,then i started the engine and undid the bleed nipple whilst my wife pressed down on the footbrake. the pedal went to the floor where she held it until i tightened the bleed nipple.the problem now is that the brake pedal will not return up to it's normal position but lays spongy about 2" from the floor.any suggestions please because i can't think of any cause for it.
