My eBay AX again folks
Thought it was the battery.... But put a new one in and whilst it behaved perfectly for a week its doing it again.....
Turn key - all lights on dash light up, glow plug lamp goes out - turn key further and nothing, not a click, nowt.
Repaeat 2 or 3 times, car starts like nothing was wrong. Checked all the wiring I can get at and everything seems sound.
Did do this previously, but rewarded me with a slow "whu....b" of the starter trying to turn (so thought battery was cooked and replaced).
Voltage at battery terminals 14.5V when running and 13.8v when off. cant do a drop test as arms not long enough[;)]
Solenoid?
Solenoid?
Marty,
I get the same problem with starting - turn the key, lights dim, and nothing else.
Wiggling the gearstick ( ooh err ) tends to sort the problem, and it may not occurr then for some time - it really is strange.
I think there's an earth problem somewhere, and wiggling the gearstick is shaking the engine / gearbox enough to make the contact - interestingly I have never ( touch wood ) had the car cut-out, so it must be starter electrics related, rather than fuel feed / solenoid area. I wonder if they are on different earth returns ?
When it starts, the starter turns quickly and the engine fires ( except I'm now a glowplug down, I think ), so I think my starter itself is sound.
I had a similar problem with an old fiesta, it was the moulded plug on the end of the ignition feed to the starter. I had to reach down and give it a wiggle and still bear the scar on my forearm from the downpipe. Needless to say a repair kit was promptly fitted.
Go on, now tell me your ignition feed is screwed on with an eye and nut affair.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by vanny</i>
maybe we need to have an inpromptue get together and fix cars! Hmm wonder if i can get insurance for my mums AX, and we could have our own AX get together
sounds good to me!!!!!!!!![:D]
Guess whats happened now!
Mother in Law reversed into drives side of car last night completely wreking the drivers door - stoved in and nicely creased, window winder now non functioning and door a good inch or two nearer to me when sat in the car.
Not a mark on her 206.
There is simply <i>NO</i> justice in the world.
Will post a photo later - looks like a trip to the scrappers is in order!
