Push or Pull Clutch?
CommY
Unread post by CommY »
Hi All
I am replacing the gearbox in my 1997 1.9TD Xantia with one from a 1994/5 1.9TD car. I know there are two different types of clutch (push/pull) but what was the change over date or were they in production simultaneously. Is there any way to distinguish between them or am I going to be safe knowing that the 1994/5 Xantia will have the same type of clutch installed as my car.
Cheers
Gary
nick
Unread post by nick »
As far as I know all Xantia 1.9TDs had the pull type clutch right through production, so you should be ok.
Kowalski
Unread post by Kowalski »
The 1997 and the 1994 should be the same clutch, if they're the same gearbox.
I have seen another clutch listed for the 1.9TD for 1998 onwards, but I can't tell you a lot about it.
beezer
Unread post by beezer »
A way to tell is (although there are a lot of cables and hoses strapped to the gearbox) by looking at where the clutch cable connects on the gearbox. There is a moving arm and a static arm. If the moving arm is nearer to you (front of car) than the static arm then you have a push clutch and if the static arm is nearer to you then you have a pull clutch.
CommY
Cheers Chaps!!
