dead 306
martyb2
dead 306
I got a 306td that needed an engine change cos the previous owner blew a big hole in the back of the block, and changed the engine, now the damned thing wont start. Does anyone know if it has an immobiliser fitted to the pump. Car is a 1996 new style 306, has a plip type key, and it has a lucas pump with a blue plug and a black plug on it. I had to change the pump, and i have checked the valve timing etc about 5 times and it seems to be ok. Any advice is aprreciated. Thanks in advance
beezer
martyb2
cant find anything that resembles a stop solenoid on it. the blue plug has 3 wires on it, and the black plug has four wires on it. one is green, one is green and yellow, one is white and the other is red.
as far as i can work out the green ones are earth, the red is live, and i dont know what the white one is.
beezer
martyb2
beezer
martyb2
Dave Burns
- x 3
martyb2
beezer
martyb2
Dave Burns
- x 3
martyb2
bad driver
2 things, first is the PMH number correct on the pump? The pump timing could be well and truly out. If the pump timing is correct then best thing to do is listen to the top right of the pump, above where injector pipes come off as someone turns the key. You should be able to hear the solenoid click. If it doesnt then I would say the immobiliser is stuck on. You can grind the steel cover off, take the solenoid out and replace with a standard solenoid off another lucas pump, or one from gsf, hard wire it to a live when ignition on wire. That will resolve any immobiliser issues. If it still doesnt start then the pump is probably well out. Any diesel pump specialist can set it for you easily enough, not too difficult a job.
martyb2
it is the original pump from the car. the pump timing and valve timing all seem to be correct, I checked them both about 5 times, but with it sitting for so long, i thought it could be possible that the rubber part of the plunger inside the solenoid could be stuck. When I checked the timing, I set both engines up to exactly the same marks, and then swapped the pump. I did note that the studs were in a different position with the bosch pump than the lucas pump, so i changed them to the same position for the lucas pump from the original engine
