why didnt you stick with the bosch pump??
Switching the pumps can be very tricky to do, try the solenoid, you could take an injector pipe off the top of an injector and turn it over see if any diesel is cooming through. If nones coming through at all then the solenoid is likely suspect. If it is then check the glowplugs are getting hot. If they are then I would suggest the pump timing is checked either by calling out someone with proper lucas timing tools or trying to hire the toll and DIY. Haynes gives a guide on how to do this.
dead 306
beezer
It seems to be that the immobiliser is preventing the solenoid from being energised. If the Bosch pump is without an immobiliser then I would swap them back. Bosch pump usually goes with Bosch injectors and Lucas with Lucas. Quite possible there are different delivery patterns etc. Problem is you should have marked the position of the pump before renewal. You should be able to get it started anyway and get it properly timed later. Most engines (s/h) are purposely sold with the pump to avoid all the hassle of timing.
martyb2
